I have been trying to get the W800 plugin that was written for HS 1.7x to work with HS2. I have found TONS of posts on the HS forums that people are using it with HS2 just fine by Rupp, Jon00 and many others.
My question is how exactly does one get it to work with HS2. I have installed the files in System 32. the OCX and DLL in the HomeSeer dir.
I see this in the HS2 log when it starts up:
12/6/2009 1:20:03 AM - Info - Found plug-in: W800 RF (32Bit) Controller, version: 2.1.0.0
When I go into HS setup/interfaces, it lists:
W800 RF (32Bit) Controller ENABLED hspi_W800RF.ocx 2.1.0.0 License Included
When I enable it (like the line copied above), if I reload the page, it again shows that it is disabled. Also, where can I tell HS2 what com port to use for the W800? I have used the W800 demo app, and can receive codes and such, and it is currently on Com 4.
I am simply trying to monitor a couple of DS10a door and window switches, and thus do not want to spend the $40 for the HS2 plugin.
