I had thought about girder, as Road Runner supports it natively. But it can be a tangled mess to work with at times to say the least, and have been trying to avoid it :unsure:
That's fist statement was incorrect and should have stated that the asp engine did change ...
Yes, HomeSeer now uses the ASP/ASPX.net Microsoft engines.
Very nice Rupp, it may be worth the switch. I have downloaded and registered HS2.0 and figured I would start fresh with this and Road Runner. I did the ASP pages mainly for a touchscreen interface with 1.7x in the house on the touch screens. Using a web browser certainly has its limitations. Using Road Runner now, I am able to communicate back and forth directly to update the clients with status, and execute events, device status ect.
Here is a screen capture, in it's early stages. All of the buttons work perfectly, and even speaks on the client machines when a button is presses, such as after "Movie Time", you hear on the overhead speakers "Setting lights to optimal movie viewing level." All that is left is to set the indicators in the skin to see the status of the lights/devices.
Not in the screen capture, is the dimming control. When you press the far right of one of the buttons, a pop-up appears with a slider to control the dim level on the devices.
Thanks for all the help and suggestions!
EDIT: With my new found control
I was able to add a Pop-Up screen in Road Runner to show the caller ID and photo, if available, on the remote machines.
