...(See photo for setup)... I cannot access the photo...
E eufreka Active Member Nov 5, 2007 #16 BraveSirRobbin said: ...(See photo for setup)... Click to expand... I cannot access the photo...
BraveSirRobbin Moderator Nov 6, 2007 #17 eufreka said: BraveSirRobbin said: ...(See photo for setup)... Click to expand... I cannot access the photo... Click to expand... ah, you Firefox users... Here is a direct link: http://www.cocoontech.com/uploads/post-7-1072944430.jpg
Sacedog Active Member Nov 6, 2007 #18 BraveSirRobbin said: eufreka said: BraveSirRobbin said: ...(See photo for setup)... Click to expand... I cannot access the photo... Click to expand... ah, you Firefox users... Here is a direct link: http://www.cocoontech.com/uploads/post-7-1072944430.jpg Click to expand... LOL. I'm guessing this particular wiring method is nowhere to be found in the NEC.
E eufreka Active Member Nov 6, 2007 #19 BraveSirRobbin said: eufreka said: BraveSirRobbin said: ...(See photo for setup)... Click to expand... I cannot access the photo... Click to expand... ah, you Firefox users... Here is a direct link: http://www.cocoontech.com/uploads/post-7-1072944430.jpg Click to expand... Actually, the link in the original post doesn't work for me with EITHER IE6 or IE7...but the direct link does...
BraveSirRobbin Moderator Nov 6, 2007 #20 Sacedog said: BraveSirRobbin said: eufreka said: BraveSirRobbin said: ...(See photo for setup)... Click to expand... I cannot access the photo... Click to expand... ah, you Firefox users... Here is a direct link: http://www.cocoontech.com/uploads/post-7-1072944430.jpg Click to expand... LOL. I'm guessing this particular wiring method is nowhere to be found in the NEC. Click to expand... YOur right, this was just a test setup...
Rupp Senior Member Nov 7, 2007 #21 If you use a split core CRMagnet then it's a "cleaner" electrical connection. http://board.homeseer.com/attachment.php?a...mp;d=1154207945 BTW How do you insert an image on this bulletin board now?
P politics123 Active Member Dec 10, 2007 #22 Rupp said: If you use a split core CRMagnet then it's a "cleaner" electrical connection. http://board.homeseer.com/attachment.php?a...mp;d=1154207945 BTW How do you insert an image on this bulletin board now? Click to expand... What if I wanted to monitor a 220v water heater? Can i use the same CR?
