I'm working on a two-way driver for Premise that uses the vmccontroller to control Windows 7 Media Center. Some things I'll be including in the Premise module are the ability to: send a msgbox to Media Center (could be used for a door bell alert, caller id, weather warning etc), grab metadata of what's playing and discrete control over ethernet for all extenders and the main PC running Media Center.
The only issue is VMC Controller is an add-in for Media Center, so it will not accept a socket connection if Media Center is not open as it will not be running
Is there a simple way to open Media Center on a remote PC using vbscript and/or some third party utility? I'm betting there's an easy way to do this. All that's really required is to run an exe on a networked PC. Any suggestions are welcome, but keep in mind I'm not a programmer. However, I'm very pretty good at vbscript and if the solution is vbscript based, I'll be able to get it to work (after some effort of course).
