I have a 1-wire weather station with an AAG anemomemter, Rainwise rain gauge converted to 1-wire, and hobby boards temperature/humidity, solar, lightning, and barometer boards. Everything was working fine and my data uploaded to CWOP was looking good. One day recently my software was unable to see any of the 1-wire devices in my weather station. It appeared that the bus may have been shorted. I think that may have been due to moisture. After everything came back to life it appeared to be working OK, with all the readings being reasonably close to CWOP and no 1-wire errors being reported by the software. But this evening after sunset the humidity spiked up to 100% and has stayed there for an extended period of time. I have another humidity gauge that reads 70%, which is probably about right. I'm not certain if this is related to temperature or not (it was above freezing today, but dropped below freezing shortly after sunset). I will observe the behavior for another day or two and watch for any pattern.
Do I need to replace the humidity sensor or is there something else I should be looking at?
Seth
Seth
