v5.1.0 is now available for download.
In addition to the major version 5 improvements this update includes these enhancements:
- Added support for new INSTEON module: FanLinc.
- Added support for new INSTEON i2CS firmware modules, including: Motion Sensor, TriggerLinc, I/O-Linc, KeypadLinc Dimmer, SwitchLinc Dimmer, SwitchLinc Relay, Thermostat.
- Added ability to create INSTEON scenes that control relay modules to OFF (versus ON) during execution.
- Improved reliability of receiving INSTEON commands from the PowerLinc 2413U and 2412U.
- Fixed bug that would cause the brightness edit field in the Set Brightness action panel to reset to 0 for KeypadLinc devices in some cases.
- Fixed bug in "If time between" and "If time not between" conditions which didn't evaluate correctly in some circumstances.
- Fixed device state "between" and "not between" condition comparisons so that ascending numerical ordering isn't necessary.
- Fixed bug that would cause errors in the Event Log when editing INSTEON links on a newly created device.
- Fixed bug in optional SQL logging client that caused plugin thermostat state changes to fail to be logged.
- Fixed bug that would sometimes cause compile errors of embedded Python scripts when switched from the AppleScript embedded type.
- iTunes Plugin: Catching an exception that is apparently a bug in iTunes - we will log the error but attempt to continue processing.
- NOAA Plugin: Added additional error handling for unknown connection errors.
- DirecTV DVR Plugin: fixed bug when validating a channel change action configuration.
- Plugin API addition: Added <CallbackMethod> element to ConfigUI checkbox fields so that whenever the user clicks the checkbox the specified callback method will be called (it works like button fields). See the popup menu docs for details.
- Plugin API improvement: Creating plugin subclassed devices (relay, dimmer, thermostat, etc.) from python is now possible.
- Plugin API improvement: Added calcCrc argument (defaults to true) to sendRawExtended() for changing settings in i2CS firmware modules.
