I decided to start a new thread just about converting Insteon to IR, instead of trying to hold multiple discussions in my other thread.
Basically, I would need to link my IR and Insteon (or any other control system) together. My current plan was to use the Ocelot's IR powers to control the erqupment and would use an SECU16 to "Push" buttons on my ControLinc, which would activate a lighting scene.
I opened up my ControLinc, and saw that for buttons it had little pieces of exposed metal that are basically two interlocking "E"s (for lack of the proper term), but they do not touch. When you press the button down, it connects the two sides. I was thinking of soldering wires to each side (trying to avoid solder connecting the two would be very hard), and then hooking it into my SECU16. The Ocelot would then close the input when necessary and "push" the button starting the scene.
That would work perfectly, but my only concerns are reliability and saftey. As I am planning on putting this system in the Church's theater (so it would be one touch operation) basically, I'm taking something that is untested and jumping right to production. Of the people I've talked to, one person is worried that it will get stuck in an infinte loop somehow, and the lights would be going on and off constantly, starting a fire (I have no clue how this could happen, but that's beside the point). I beleive that that would only happen if the coding for the Ocelot was faulty or the Ocelot would somehow crash. Has anyone had an Ocelot crash?
As of right now, this seems like the only option out there. Can any of your DIY minds come up with another solution? I would like to stay away from things that require a computer because it would be a waste for it just to control one room (the theater). Also, last time I tested X10 in the room, it did not work.
Any comments, ideas, or suggestions are greatly appreciated, as I am unsure of what to do.
