I tried removing the APC rack mounted surge strip and the structured wiring UPS (APC as well) and thought I concluded that X10 (with a controller) did not work from there. I'm going to rerun the test though.
I was also playing with the Elk beta for Insteon and that did not appear to work either. That one the APC UPS was running, so I want to rerun the tests again.
Is there anything else I should be testing, or that might contribute?
I know there is a GFCI outlet on that circuit, and after looking further it looks like there are some older style outlets I hadn't noticed (2-prong, but an older style that I don't find anywhere else in the house. I have not cracked open the outlets as they are behind some shelving and haven't gotten into it that deeply yet. House was built in the mid 50's).
Could any of this impact this? I have been able to use X10 elsewhere in the house (although mostly manual and not that often). I've also been able to use Insteon upstairs without any issues (using a controllinc).
I'm going to use an insteon controllinc to test from that circuit as well as another test.
