Any control with a normally (N.O.) isolated output contact may be connected in parallel with the OPEN button.
Ah well you could tap into the poe to power an external relay, matching the coil voltage to the poe supply.Bartmandude said:Hi az1324
Problem is my iTach is PoE
This is for a commercial door opener, which is hard wired, so I guess I'll get the Elk relay and I'll have to run an extension cord to power a 12V pwr supply.
This adds complexity that doesn't need to be there.az1324 said:Well the iTach still uses a DC power supply so it could power a DC relay and a Y cable and relay is <$5. Removing the protection components would be free.
Bartmandude said:Um... what is RIB?
Police lingo ... Also Known AsFrederick C. Wilt said:Um... what is AKA?![]()
