BraveSirRobbin
Moderator
Hi Eric;
I purchased the "uncoated" Leaf Wetness Sensor from you over a year ago. It works well with a DS10a (replace the door/window contact with the Leaf Wetness Sensor) for use as a water sensor (for under sinks, laundry room floor, etc...).
I see on your site that you make this statement:
Has this statement always been there? Has anything been changed or added to this sensor over the past year. Reason I ask is because the coated sensor (which I can't seem to find on your site) did not work at all with the DS10a. I'm just wanting to make sure that their was no coating put on the first one recently that would have changed it's sensing properties (i.e. different than the uncoated one I purchased a year ago).
If so, not a big deal, I'll just buy some more and test them. I just had some people interested in this method of water detection recently
BSR
The sensor does not have the green solder mask which will make the sensor more sensitive but now includes gold plated traces to keep oxidation to a minimum.
BSR
