Dave is right. You should never run a plain lamp cord IN the wall and especially NEVER a plain splice in the wall. Besides the issue of lamp cord not being rated for use in wall I believe code states you can not have any kind of joint or splice in an area that is not accessible, which means not in a wall. The right way to do it is to run romex (possibly in conduit depending on your location and code, check with an electrician or AHJ) into a junction box. You would then mount the light to that. You can pull those wires to your electrical room and power them there in any configuration you want.
Other options may be low voltage lights. Code *may* allow you to have the transformer in your electrical closet and the LV wire in the wall, then you can likely just do the small hole thing. Or, there are also battery operated picture lights but you will have to figure out a way to hack a PIR into it. Check with a large place like this. You can get motion activated battery powered lights but the are not in the 'art' form factor. Like this.
