Steve said:
How well (and how difficult would it be) to use this as a car monitor? I've been looking at all the methods and was thinking I like the potential of this. What about if you install one of these say in the ceiling of the garage where the car goes? Would it be able to detect the presence of the car (distance changes from like 8 feet to like 4?) I guess it could be subject to false detection if a person walks under it when a car is not there?
You could install this sensor on the ceiling and it will measure between six inches and 255 inches with one inch accuracy. If you open the serial port and let the system "free run" it automatically has the data available on its TX port and will update a few times a second. The response is very fast and accuracy as stated during my testing.
You can look at the HomeSeer link referenced above for VB script code that can be used (HomeSeer specific, but commands could easily be adapted for other software systems).
There are some tradeoffs as described above. When I tested this sensor in the above scenario I found that it placed a five percent burden on my CPU usage. This may or may not be a problem for you.
There is an analog output also, but I did not want to go that way due to the limited voltage differential output over my measurement range (plus if you use an Elk Analog Input Zone you have the problem of the "pull-up" resistor that I described in other posts).
You could always play around with the options described above about "polling" the device for data to minimize CPU usage.
You could also power the device on and off with an appliance module and just "write off" the first few readings via code (requires a very small warm up time and self calibration).
True you would get a reading as a person passes under the detector, but again, you could check for "stability" in the reading via code (say the "change" has to occur for x number of seconds before becoming a valid vehicle status indicator).
In my case, I'm thinking about using this for my water softener "salt level" detector. I only need a reading twice a day and will just use an appliance module with software methods described above to validate the data via HomeSeer.
I like the fact that I can measure salt level without having any type of string touching the salt/water. I haven’t implemented this as I've been busy with my son graduating HS and all.
Another reason for cycling power to the device is my garage gets well over 100 degrees F in the summer and I only want power for a few seconds in this environment.
I couldn't find operating temperature recommendations for this device, but it may be a concern if placed in very hot environments.
