More Insteon products?
Steve said:
I do not disagree, but it is important to understand my apples to apples argument. You can not compare an Icon to a UPB switch, that is apples to oranges.
A 600W switch is a $20 difference at retail and a 1000W dimmer is less than $10 difference at retail. I don't dispute UPB is more, but not drastic when comparing similar switches.
Other than a lower rating, the Icons I have the same feature set as my V2s and Keypadlincs (except for perhaps a smaller link table, which is not an issue for a small or medium install). So for a small load, I can easily do an apples to apples comparison to UPB. There is no need to put a 1000W capable switch on a 75W load. The Fry's switch might be an option for lowering UPB cost in the short term (until they run out)...
One of the main points I tried to make in my original post: you must look at the actual application before determining the "best" solution. You mentioned earlier that it is necessary to looks at the total cost of the system (including controller, phase couplers, replacing dead components, etc), and I completely agree. Load size can significantly affect the cost of an Insteon system, so it must be taken into consideration...
Chris
ChrisWalker said:
I would venture to say that, by volume, Z-Wave devices are the most popular standards-based products in the market (other than X10).
Chris
Chris,
Since UPB had been in the market since about 1999 and Z-Wave since about 2005 I would add UPB to the list with X10. And let's not forget LONWorks which is poorly priced for the mass market - this is changing - and has shipped something like 60M units.
I'll go out on a limb here and say that it is possible that Control4 has shipped about as much "ZigBee" product as the Z-Wave alliance member companies have shipped z-wave. We can argue all day about how standard the C4 products are, and I will take either side of that argument. C4 is probably the largest single customer for ZigBee right now by a large margin.
I have heard some pretty fantastic numbers about z-wave shipments from Zensys and frankly they don't hold up under any kind of scrutiny even at the point of delivery.
Back to the main thread. All of the technologies mentioned will enable the original poster to do what he wants. Some have more complete and different product offerings than the others but the differences are at the margins. A for instance is the INSTEON Toggle Link dimmer from SmartHome which does not have an equivalent in the Z-Wave world AFAIK. If the WAF depends on having toggle switches then that will be a driving requirement.
One other editorial comment. Everything that I have seen says that on the whole you will be happier with a wired or power line solution than with wireless only. YMMV and if anyone wants to hear about some of the whack approaches that are being discussed to "fix" the different wireless protocols, look me up at EHX.
George West
DeLicious said:
you obviously haven't looked very hard... Automated Outlet has SAI 8-button keypads on a universal transceiver base for $89.95
Google did not find them and I could not remember their name when I was looking. With that pricing, it is only 50% more, instead of 60%.
/carmi
Just a clarifacation on the Fry's switches (go to Fry's and search for "HAL switch" to find them). Currently they're $38 each. A whopper of a deal btw...
Steve correctly identified these switches earlier in this thread as the SAI model US1130W. This switch is still being made; in fact its one of SAIs best sellers. Something Steve didn't know was that the US1130 does accept SAI's replacable faceplates. This means that you can change colors freely. You can also choose the "dual tall" faceplate configuration for a dual rocker on the same switch. The US1130 won't accept push button or 4 rocker faceplates though.
My house consists entirely of these switches. They can be a challenge to fit into older boxes. However, I've found that I can simply use a file on the square plastic corners to round them out. This technique became a quick and easy way to get them to fit into some of the older boxes in my home (built in 1958).
Build quality and color control is excellent. Here's a pic of of an upgraded 3 gang wall plate in my house showing this:
Here's my (in)famous picture showing how this same wallplate looked with switchlincs. I've used this one before during a Switchlinc rant on this forum....
The above picture represents Switchlincs from 2000 to 2004. Notice how many times the appearance as well as the "white" color has changed in a mere 4 years. I won't ever buy another Switchlinc in part due to Smarthomes horrendous build quality. A quick search of this forum will show that Insteons suffer from this same (lack of) build quality.
Granted, the picture does show 4 years of switchlinc production. However, by comparison, here's a 2 gang wall plate showing US1130s installed 2 years ago:
As you can see, there's zero styling differences to the 3 gang switches I installed two years later..
Bottom line here: UPB isn't as expensive as you would think and the build quality is professional grade. The 1130 is rated at 1000W for a reason: it's a sherman tank. Most of the switchbody itself is a huge heatsink.
Yep, you are correct. I was speaking in very broad terms as in the full line of faceplates like the US240.
FWIW Fry’s website say to “Call for Availability†so I did…
The girl on the phone said that they were out of stock on the HAL switches. She also said that the manufacturer had missed the last three delivery dates with Fry’s and that she couldn’t honestly predict when she would have any in stock. She did mention that there were “a lot†of backorders to fill so that when they do get in a shipment, they may run out of stock again soon afterwards.
Link to item: HAL UPB switch at Fry's
Terry
Edit: Hey cool, 100 posts! I'm "Advanced" now. ;)
Yeah, my distributor, DPC, ran out recently too. I believe this happened because SAI was running a "buy 5 get 1 free" deal to distributors on the US1130W through the end of October. (I must admit that I took home my share of free switches, thereby contributing in some small way to the shortage ;) )
Demand must have gotten really high and SAI apparantly couldn't keep up... They're back in stock at DPC now though so I imagine Frys will catch up soon too.
As a relatively new Insteon user, I've had a really good experience so far. I just moved into a 1954, 1400sqf house and have 9 devices installed, mostly to control lights. The house doesn't have neutral wires in all the most convenient places, so I've had to install a few inline modules in places.
My biggest gripe so far is the lack of devices. The new SimpleHomeNet devices are a start, but they seem to be the only company outside of SmartHome doing any Insteon development.
RonX said:
I was on the same decision, I finally went with Insteon because I know I will hate UPB delay (the price was a factor too). I like Z-Wave, but I can't use it since wall boxes are all metal (house is built with bricks and concrete).
Hmmm, as someone who is considering switching to z-wave, this can't be true. My house also has all metal gang boxes. Does z-wave really not travel well through them?
