wuench
I have often thought that power line control would be much more reliable if xmitters and receivers had two way communication so that the receiver would acknowledge receipt of a command and if that did not happen that the transmitter would resend the command. Perhaps some of these, new to me, protocols have that feature. I have not had time to read about all of them yet.
Yes, Insteon does have that feature. Insteon devices send an initial group command to the powerline. Members of that group will perform the requested action (turn on, off, whatever). After sending the group command, the sending device then sends a direct "cleanup" command to each member of that group, to be sure they heard the initial group command. If the responder does not acknowledge, the sending device keeps retrying the command until finally giving up (after 5 tries).
Unless another device sends an Insteon message, then group cleanup is abandoned. This is the primary reason group communication is less reliable than single switch commands, and why you may be able to turn a light on individually, but when you issue a group/scene command it will fail.
