I am planning on installing my structured wiring panel very soon, but before I can do this, I need to build the wall. I decided to focus just on that one wall, and not the entire room for now. The wall will be under a main beam, which means I would have to use 2x6 lumber if I want the wall to be flush with the beam. Since I can't drill through the beam in order to run the wiring to the panel, I decided to have it stick out a little by using 2x8's.
Then I reliazed that most of my PC cases could fit in the wall (if I place 2 of the studs farther apart of course), except for 1, so I started thinking ... should I switch to 2x10's, and put all my PC hardware in the wall, right next to the structured wiring panel? The only problem I can think of is heat, but adding an exhaust type setup might deal with that problem.
Here is the beam in question:
http://www.marstracker.com/gallery/persona...ng/P4113246.JPG
What do you guys think? Good/Bad idea? Any suggestions? Thanks!
