murphy
Now it's becoming Christmas-time. Here is my wishlist for the ELK-system.
Maybe you all feels other priorities or having other needs. I would appreciate the following points:
1. If you are selecting the military time format and the metric system, it would be great, if the rules expressing also these measuring system only. So the rules becoming easier to overview.
2. The voicelist 0.8 should become a new extended version with some more usual words. Until now, I missed these words:
car - counter - irrigation - rain -
basic colors as: red - green - yellow - blue - white - black -
orange - pink - brown - gray - violett - dark - light
and maybe some timezones: GMT - ET - EDT - CT - CDT...
as dimensions: Celsius - Fahrenheit
and -as a joke- the baby should be able to speak: mama - and his name: ELK !
3. The voice-menues, are generally using a fall back in menues by (a timer or) the star-button.
Except when in menue 7=listen in. Here you are using 9 9 to exit.
That should be changed also to the star-button.
4. When listen in, by phone, and there is some backgroundnoise (even low level fans or so) than the system is not recognizing button-commands (as 7=extend time). Now the incoming and the outgoing sound is coming via diffent wires and therefore it should be possible for the voice-responding systen to listen only to the phoneline for commands.
5. The ELK-RP-programm has a good option: showing the status. But only for the state of the zones, the inputs. It would be great if you can see the state of other things as: outputs, lights, counters, troubles, temperatures ...
6. The voice-responding subsystem can tell you the state of every light, zone, output, temperature-sensor etc. Wouldn't it be nice, having a menue point where the system is telling you also the counters, as
"counter twenty-seven is eight three six".
At least for me, this is useful for checking conditions and events.
7. The rules are rather powerfull.
For a trigger you can compare temp-sensors with counters. But you can't compare two counters (, which are not defined as temp-sensors). I hope, this option is becoming possible with the next version of ELK-RP.
Also as an action it is not possible adding an amount from a counter to another counter.
When using the ELK for a security task, that is maybe not too important,
when using the ELK-system for HA it will be comfortable.
8. You can send a text to a port as to a keypad. But it would be nice also sending a text to the logfile. Where the text is noted with a timestamp. For easy testing and reporting etc..
IMHO all these are usefull improvements making the ELK even more
powerfull and more flexible and more userfriendly.
And all this should be easy to realize.
Any other ideas or suggestions or needs improving the ELK ?
