ctay
IVB is the stud when it comes to wiring diagrams. I can only add what I plan to do for EDT. EDT is designed to run daisy chained from switch to switch around the house. I don't really like that as I think it limits my future options. So what I plan to do is to run two Cat-5 to each switch location back to a central patch panel. From the patch panel I can easily connect any switches together to form the mother of all daisy chains. you should be fine with this method out to 500 ft. However, 500 ft isn't very far when you consider all the back and forth you have to do from each switch... BUT I have a plan to overcome that also. EDT has a "line extender" device that is essentially an amplifier that can allow you to go another 500 ft. The extenders aren't very expensive so it doesn't add a lot of expense to the system. With a couple of extenders and four independent "branches" I think you can cover a large home with out any trouble.pjwinstalls said:It would affect my wiring runs if i did EDT hardwired controls. What do you think of them?
Chris
P.S. here are some EDT threads...
EDT iLine Questions
OnQ vs EDT
