86turbodsl
Ok, I just had the sheetrock go up, and I pre-wired about 7-8 zones with single gang LV j-boxes and cat5 and audio to each one.
I then ran speaker wire to each speaker location and tucked into the rafters for later.
I'm befuddled by the different systems out there.
A-bus sounds interesting, but I'm not sure if it meets my needs.
I'm looking for two channels that each zone can select from, although more might be nice...
Would two recievers in the wiring closet and each keypad location can select from either one be possible?
I figured the cat 5 would be for selection, volume control or whatever, and the audio would be carried on the audio cable, but
perhaps that's not the way it works.
I want this to be fairly inexpensive, so spending 2K is not an option.
Anyone have ideas?
Basic wants at each location - simple controls, A/B select, no display needed. Manual control required, we don't want lots of IR remotes floating
around the house, although capability for that would be nice for me, not wife.
thanks
EDIT: Stuff I forgot: Two main sources wanted - 1. FM Radio 2. MP3's off the server. Not looking to have CD/DVD/Tape/whatever at each zone.
Anyone have ideas?
thanks
