I think that question was asked and answered in the older 1220 model thread, somewhere in these forums. Or if someone here remembers, maybe they can repeat it.
Do you remember what the answer was ?
Thanks.
Technically speaking, it isn't "two phases". It is a center-tapped transformer with the middle being the neutral (zero volts) and the ends being the mains feeds (the so-called two phases). End-to-end is 240V and end-to-neutral is 120V. Since it is coming off the same transformer, then end voltages must be nearly identical (but opposite). There is some possibility of inaccuracy, but not enough to worry about for residential use. I think BrettS took a bunch of readings in his house and only saw a couple volts difference between the legs in a worst-case scenario.As many know, in the US electricity is provided via two 120V/60Hz phases shifted by 180 degrees with respect to each other. High consumption appliances are connected to both phases thus effectively being fed at 240V.
Now, as far as I understand and please correct me if I am wrong, the ECM-1240 has only one voltage channel and two current channels (two CTs). So, how can the device calculate energy consumption if it "knows" only one phase voltage ?
The need for the voltage reading in a power meter is primarily for two things: 1) to read the peak voltage and 2) to know where in the voltage wave cycle you are. For true power metering you have to compare the current reading with the voltage reading at that particular instant. On some device (incandescent lamps) the volt and current curve will match nicely, producing a power factor of 1. On some devices (computer switching-mode power supplies), the voltage and current curves are not lined up and you have a power factor less than 1. It is these types of device (PF<1) that require the voltage reading to get the true power reading. If your house was nothing but incandescent lamps and toasters, you wouldn't really need a constant voltage reading (assuming your voltage was stable and reading the voltage once was good enough)
How far can the CT's be extended? I would like to use CAT6 to carry the CT outputs from a JB with terminal strips under my panels to the 1240.
I would rather mount the unit in a panel on my structured wiring wall. About 50' away from both panel boards in my house.
That appears to be correct. I believe that all of the residential monitoring devices we have seen or discussed on CT only measure one leg (unless they don't measure at all, which makes them inaccurate).Anyway, my understanding is that with ECM-1240 only one phase voltage is measured and the other voltage is assumed to be the same. Is that correct ?
You should be fine:
http://www.brultech.com/HomeEnergy/homefaq.html#I2
This question was asked last year and I do not believe I have seen the answer.
Thanks.
And now I've got a question, since the basic unit with just RS-232 comms aren't in stock yet. Is the A+ package with "wireless" (plus the RS-232 serial output) basically an internal zigbee transmitter with an INCLUDED Zigbee to USB dongle? I couldn't be quite sure from the Online store description. I didn't want to order that package and find out that, yes the 1240 did have a built in wireless data transmitter/xcvr, and find out when I received it that the wireless to USB dongle was extra...
Now I have a question. I will need the micro-CT's that support aluminum wiring (which I have some of), which I imagine are just a little larger. Will these same micro-CT's work on the copper wiring as well that is slightly smaller?
Yes. The only difference is the physical size to allow for large Al wires for a given current rating.
From what I can tell it does not include the Zigbee to USB dongle. It seems to be $99 extra (AFAIK a decent price). I am not interested in the wireless right away, but may need it someday. PKG A+/100 seems reasonable.
