wkearney99
Westcojack said:For my 2 cents, if you get the right lighting control expert to do the lighting controls, keypads is the only way to go. Traditional multiple gang switches look terrible, and guests always have to hit 2-3 switches to get lights on and off, three way switches cause confusion, etc. With a lighting control system pressing the Room On button (we always engrave every button) is a no brainer, as well as the Room Off. Most users of our systems really like the Dinner button, or Clean Up button, or Low button (like a dim scene to watch TV or a movie), or Path To Kitchen button, and rarely ever use the buttons that control single lights.
Make sure to get and call a few references from the automator, and ask how easy it is to use the system, are they happy with it, and was the automator reliable.
I agree that banks of dimmers strung out along a wall can indeed look terrible. But that has more to do with just bad circuit layout than automation. That and over-lighting a space. Whenever I've seen a multi-gang wall plate, or worse several side-by-side, it's usually because there's too much lighting and not enough planning.
As for scenes, some folks do indeed like them. Me, not so much. There's a limited number of buttons on a keypad, but many rooms get used for more than one purpose; on different days of the week, at different times of the day. So while "Dinner" and "Clean Up" are great ideas, if you want to use that space for something else then you're stuck with using some other kind of controls. I'm not saying it's bad idea, one way or the other, just that it's worth considering your lifestyle and how you genuinely expect to be using the spaces ahead of time. This can help avoid being stuck with a control scheme that doesn't fit your needs.
Personally, I like to have one plain looking paddle dimmer for the 'main lighting' used for the room and then a keypad for programmable options. This way anyone can get light into the space without having to deal with the tiny little keypad buttons.
All of my keypads always include using the bottom-most button for "All Off" for the area. This is a winner with everyone that's used it. Lutron has the nice feature of being able to add delays to actions, so when you hit "All Off" it can be set up to immediately turn off most lights but delay turning off your exit path; gradually dimming it as you leave.
I think where things are starting to get more exciting is with voice control. Now THAT'S a means for which I could really see using a lot of scenes. Amazon's Echo is making a lot of progress here, but it's still in it's early days. Lutron's integration options for it are as yet undelivered. That and voice doesn't work well if you want to control things during quiet times.
There's lots of great innovation happening with home automation. But it all still depends on there being a good foundation of well planned lighting. Make sure that's where you start.
