Hi, I need help in tracking down an issue that could be VERY IMPORTANT: my heating has always been controlled with the OPII, using some temperature sensors in the rooms and accordingly commanding the outputs to turn on and off the zone valves when needed.
Now in migrating to Home Assistant I have setup a series of climate entities that take the temperature data from the MQTT data provided by OmniLinkBrdige.
I set up the system but never tested it since it's summer. What I am seeing is a lot of gaps in transmission of temperature sensors data (the red line are the temperature data):
The gap is very big, from 1 pm to 7 pm roughly, and is never the same for all of the rooms: some are missing none, some are missing different hours, some have smaller gaps:
Other values form OmniLinkBridge seem to come in just fine (hard to tell exactly because apart from temperatures they are all discrete values, but all the automations that rely on PIR data worked fine the whole time). I also can see the values just fine form directly from the OPII so the temperature sensors data are there, it's just that the transmission erraticaly ceases for long periods of time.
As you can see in the graphs they are really gaps, when the temperature is stable I simply get a continuos line, so it's not an issue of MQTT broker not updating the value since it receives the same data.
What could I possibily do to track down the issue?
I'm thinking of a script to restart OmniLinkBridge when a sensor doesn't get data for a while, but that would be far from ideal since I have automations running that need data from the sensors.
Any ideas?
Sorry, don't know why I can't post images even if very small: the pics are
here
