grantlewis
rsw686 said:For full functionality you will need to add a custom_components folder to your config directory and override the following. Links to the pull requests are below, so you can track the status of these being included into the next version of Home Assistant.
alarm_control_panel/mqtt.py Adds night mode
climate/mqtt.py Adds temperature low and high setpoints
The climate/mqtt.py custom component is working for me, but HA doesn't seem to be picking up the alarm_control_panel/mqtt.py entry.
Code:
This platform enables the possibility to control a MQTT alarm.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/alarm_control_panel.mqtt/
import logging
import re
import voluptuous as vol
from homeassistant.core import callback
import homeassistant.components.alarm_control_panel as alarm
from homeassistant.components import mqtt
from homeassistant.const import (
STATE_ALARM_ARMED_AWAY, STATE_ALARM_ARMED_HOME, STATE_ALARM_ARMED_NIGHT,
STATE_ALARM_DISARMED, STATE_ALARM_PENDING, STATE_ALARM_TRIGGERED,
STATE_UNKNOWN, CONF_NAME, CONF_CODE)
from homeassistant.components.mqtt import (
ATTR_DISCOVERY_HASH, CONF_AVAILABILITY_TOPIC, CONF_STATE_TOPIC,
CONF_COMMAND_TOPIC, CONF_PAYLOAD_AVAILABLE, CONF_PAYLOAD_NOT_AVAILABLE,
CONF_QOS, CONF_RETAIN, MqttAvailability, MqttDiscoveryUpdate)
from homeassistant.components.mqtt.discovery import MQTT_DISCOVERY_NEW
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.dispatcher import async_dispatcher_connect
from homeassistant.helpers.typing import HomeAssistantType, ConfigType
_LOGGER = logging.getLogger(__name__)
CONF_PAYLOAD_DISARM = 'payload_disarm'
CONF_PAYLOAD_ARM_HOME = 'payload_arm_home'
CONF_PAYLOAD_ARM_AWAY = 'payload_arm_away'
CONF_PAYLOAD_ARM_NIGHT = 'payload_arm_night'
DEFAULT_ARM_NIGHT = 'ARM_NIGHT'
DEFAULT_ARM_AWAY = 'ARM_AWAY'
DEFAULT_ARM_HOME = 'ARM_HOME'
DEFAULT_DISARM = 'DISARM'
DEFAULT_NAME = 'MQTT Alarm'
DEPENDENCIES = ['mqtt']
PLATFORM_SCHEMA = mqtt.MQTT_BASE_PLATFORM_SCHEMA.extend({
vol.Required(CONF_COMMAND_TOPIC): mqtt.valid_publish_topic,
vol.Required(CONF_STATE_TOPIC): mqtt.valid_subscribe_topic,
vol.Optional(CONF_CODE): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_PAYLOAD_ARM_AWAY, default=DEFAULT_ARM_AWAY): cv.string,
vol.Optional(CONF_PAYLOAD_ARM_HOME, default=DEFAULT_ARM_HOME): cv.string,
vol.Optional(CONF_PAYLOAD_ARM_NIGHT, default=DEFAULT_ARM_NIGHT): cv.string,
vol.Optional(CONF_PAYLOAD_DISARM, default=DEFAULT_DISARM): cv.string,
}).extend(mqtt.MQTT_AVAILABILITY_SCHEMA.schema)
async def async_setup_platform(hass: HomeAssistantType, config: ConfigType,
async_add_entities, discovery_info=None):
"""Set up MQTT alarm control panel through configuration.yaml."""
await _async_setup_entity(hass, config, async_add_entities)
async def async_setup_entry(hass, config_entry, async_add_entities):
"""Set up MQTT alarm control panel dynamically through MQTT discovery."""
async def async_discover(discovery_payload):
"""Discover and add an MQTT alarm control panel."""
config = PLATFORM_SCHEMA(discovery_payload)
await _async_setup_entity(hass, config, async_add_entities,
discovery_payload[ATTR_DISCOVERY_HASH])
async_dispatcher_connect(
hass, MQTT_DISCOVERY_NEW.format(alarm.DOMAIN, 'mqtt'),
async_discover)
async def _async_setup_entity(hass, config, async_add_entities,
discovery_hash=None):
"""Set up the MQTT Alarm Control Panel platform."""
async_add_entities([MqttAlarm(
config.get(CONF_NAME),
config.get(CONF_STATE_TOPIC),
config.get(CONF_COMMAND_TOPIC),
config.get(CONF_QOS),
config.get(CONF_RETAIN),
config.get(CONF_PAYLOAD_DISARM),
config.get(CONF_PAYLOAD_ARM_HOME),
config.get(CONF_PAYLOAD_ARM_AWAY),
config.get(CONF_PAYLOAD_ARM_NIGHT),
config.get(CONF_CODE),
config.get(CONF_AVAILABILITY_TOPIC),
config.get(CONF_PAYLOAD_AVAILABLE),
config.get(CONF_PAYLOAD_NOT_AVAILABLE),
discovery_hash,)])
class MqttAlarm(MqttAvailability, MqttDiscoveryUpdate,
alarm.AlarmControlPanel):
"""Representation of a MQTT alarm status."""
def __init__(self, name, state_topic, command_topic, qos, retain,
payload_disarm, payload_arm_home, payload_arm_away,
payload_arm_night, code, availability_topic,
payload_available, payload_not_available, discovery_hash):
"""Init the MQTT Alarm Control Panel."""
MqttAvailability.__init__(self, availability_topic, qos,
payload_available, payload_not_available)
MqttDiscoveryUpdate.__init__(self, discovery_hash)
self._state = STATE_UNKNOWN
self._name = name
self._state_topic = state_topic
self._command_topic = command_topic
self._qos = qos
self._retain = retain
self._payload_disarm = payload_disarm
self._payload_arm_home = payload_arm_home
self._payload_arm_away = payload_arm_away
self._payload_arm_night = payload_arm_night
self._code = code
self._discovery_hash = discovery_hash
async def async_added_to_hass(self):
"""Subscribe mqtt events."""
await MqttAvailability.async_added_to_hass(self)
await MqttDiscoveryUpdate.async_added_to_hass(self)
@callback
def message_received(topic, payload, qos):
"""Run when new MQTT message has been received."""
if payload not in (STATE_ALARM_DISARMED, STATE_ALARM_ARMED_HOME,
STATE_ALARM_PENDING, STATE_ALARM_TRIGGERED):
_LOGGER.warning("Received unexpected payload: %s", payload)
return
self._state = payload
self.async_schedule_update_ha_state()
await mqtt.async_subscribe(
self.hass, self._state_topic, message_received, self._qos)
@property
def should_poll(self):
"""No polling needed."""
return False
@property
def name(self):
"""Return the name of the device."""
return self._name
@property
def state(self):
"""Return the state of the device."""
return self._state
@property
def code_format(self):
"""Return one or more digits/characters."""
if self._code is None:
return None
if isinstance(self._code, str) and re.search('^\\d+$', self._code):
return 'Number'
return 'Any'
async def async_alarm_disarm(self, code=None):
"""Send disarm command.
This method is a coroutine.
if not self._validate_code(code, 'disarming'):
return
mqtt.async_publish(
self.hass, self._command_topic, self._payload_disarm, self._qos,
self._retain)
async def async_alarm_arm_home(self, code=None):
"""Send arm home command.
if not self._validate_code(code, 'arming home'):
return
mqtt.async_publish(
self.hass, self._command_topic, self._payload_arm_home, self._qos,
self._retain)
async def async_alarm_arm_away(self, code=None):
"""Send arm away command.
if not self._validate_code(code, 'arming away'):
return
mqtt.async_publish(
self.hass, self._command_topic, self._payload_arm_away, self._qos,
self._retain)
async def async_alarm_arm_night(self, code=None):
"""Send arm night command.
if not self._validate_code(code, 'arming night'):
return
mqtt.async_publish(
self.hass, self._command_topic, self._payload_arm_night, self._qos,
self._retain)
def _validate_code(self, code, state):
"""Validate given code."""
check = self._code is None or code == self._code
if not check:
_LOGGER.warning('Wrong code entered for %s', state)
return check
