Ok, so this one is driving me nuts and making the family and neighbors annoyed if not deaf!
What is happening is the system is armed in away mode. When you enter from an Entry/Exit zone the Interior sounders are going off IMMEDIATELY but a Burglary is not signaled. If the system is disarmed the sounders silence. If you just let it go past the delay then Burglary is indicated, the strobe comes on (rule turning output and relay on) and the exterior sounder comes on after the exterior sounder delay.
I have checked everything I can think of and can't see a reason that the interior sounders come on immediately. They are not referenced anywhere in a rule, there is a 30 second Entry delay (which seems to work since Burglary is not indicated right away), the zones are configured right, etc. This happened on both Entry/Exit zones. In Night mode same thing happened (as expected) and Burglary was indicated immediately.
So, what would cause the interior sounders to come on immediately when armed away without the system indicating burglary? There are no automation blocks or anything I can see that turns on the interior sounder output or anything.
