Hello,
My RC1000 has been acting oddly since it started getting cold. It is set at "Heat Only" so it has only been used for the "Fan" mode for a while. Anyway, Lets say for example, it is 65 degrees in the house. I set the heat to 67 and it comes on as normal. It will run for a while then shutdown before it reaches the desired temperature. It will then immediately restart again and continue in this cycle until the desired temperature is reached.. It does this sometimes even when it needs to make a 1 degree increase in temperature.
Before this season it has been working fine for over a year. It did stop communicating with my HAI panel earlier this year but it was because the port was bad on my OIIe. The board was still under warranty so I paid the difference to upgrade to the OPII.
Any help would be appreciated.
