System has been running fine for a while until I added buttons 9-12. They are visible in PC access (obviously I wrote them to the controller) but they are not showing either on either the consoles or in Haiku Helper.
I think You have to give a new name to your buttons in PC Access if You want to see them on your console. The idea is if You want to use buttons (Units) for control only, You may use them without need to see them on your console. It is the case for units used asFlags.
