I did a quick test here using one of the wireless phones which is on the same line as HAI OPII. I can hear the solenoid click putting the phone on line an off line. If you hear the click then I would say that your configuration might be not right? I just tested doing commands via phone and all was fine here. I do hear a slight buzz (always have though).
Next I started the core server application and see the following being logged when the phone goes on and off hook:
Next I looked at my Homeseer HAI plugin and it does track the on and off hook stuff via the serial link.
Start with the basic listening (ear to HAI panel) for the solenoid click. You should hear it when the voltage changes from on hook to off hook or off hook to on hook.
Years ago I think that there was in place a voltage shunt for bb before it went to your cable modem. Check for any voltage on your cable line before it goes to the modem. I don't think there is supposed to be any with today's modem.
VERBOSE: SystemEvent: Unhandled Raw: 55 3 2 Num: 770
VERBOSE: SystemEvent: Unhandled: 3 2: 00000011 00000010
VERBOSE: SystemEvent: Unhandled Raw: 55 3 3 Num: 771
VERBOSE: SystemEvent: Unhandled: 3 3: 00000011 00000011
