It's called "mini RG59" or "mini coax" basically the stuff that comes with your TV.
Use all copper rg59 (copper shield no foil) for optimal performance on all baseband video and audio.
This is because the foil/aluminum shielding is more effective at higher frequencys digital services utilize. Copper briad has better rejection in the lower frequencies used for most local video interconnects.
Just a few points:
Sacedog - RG59 is usually recommended for baseband because it's easier to work with (thinner and more flexible) and it almost always has a solid copper core, actually, I've never seen one without, but I'm sure they are out there.
Also, it's usefully to distinguish between your run of the mill RG6QS that you get at HomeDepot and a high quality cable like Belden 1694A. I pick some of the Leviton SW stuff at HD when I'm in a pinch, and have never seen them stock anything other than CCS RG6. So, if you don't mind your component or audio cables being a little bigger and stiffer, then something like 1694A will work for all your runs.
beelzerob - mini coax is great, and bundled mini coax like Belden 7794 (just using them as an example, there are plenty of other quality cables out there) are even better, but expect to pay a pretty stiff premium over the other wire types.
Pick your wire by it's purpose rather then it's ease of use. I am unsure if Sat or digital cable will work if you use RG59u BC with copper briad.
Also you can use Cat5e as basically a "Do-All", with the proper adapters you can run just about anything over it. Also it's pretty easy to work with too.
Well, I had a momentary lapse of reason where I considered just using Cat5 and baluns for video distribution. Now I'm back to reason. :lol:
So, here is my (semi)final wire totals and types (all solid and rated for in-wall use unless specified):
22/2 (Temp sensors, window/door contacts, smoke alarm): 2500 ft
18/2 (A/V Keypads, Touchpanel, motion detectors, CO alarms): 750 ft
16/4 (speaker): 1000 ft
Cat5e (A/V Keypads, touchpanels, PC Network, phone, TV, lighting control, motion sensors, CO alarms): 4500 ft
Mini-Coax (TV): 3000 ft
RG6QS (TV, antenna, satellite): 1500 ft
Hi,
Where are you going to purchase all your wire from?
It was me who recommended Keystone. Did you talk to Nick in Fla? He's the only guy that would know me. Don't know about where you talked to but Nick will ship orders > $500 for free, so that should answer that part of the ? for you.Hi,
I'm open to suggestions, if you have any. I'm currently pricing from 2 locations. The local lighting place (friedman electric) that will handle our lighting choices. He's going to get me prices to compare. And then the other place is keystone wire. Someone from these forums (can't quite remember who...but I did tell keystone they had sent me) recommended them, so I asked for a quote from them and they're very reasonable. They're about 3 hours away from me, though, so I'm not sure if it's economical to go get it or have it shipped.
