v1rtu0s1ty
Neil,
With the information from above,
Inrush current
@ 24 VAC = 0.35 AMPS
Holding current
@ 24 VAC = 0.23 AMPS
I beleive you should beable to open both valves at once. even the inrush (2 * .35 = .7 amps) and I would guess you wouldnt open them exactly at the smae second..... you shouldnt have a problem. and holding current for two of them running will be just under 1/2 amps....
It helps a lot. Yes, I can open the next valve a minute after I have opened the first one.
Is there any reason why I would stick with ELK wallwart rather than the RadioShack posted earlier? It's just that with the RadioShack, it's available locally. No shipping cost.
Thanks mustangcoupe!
