shenandoah75
I have kind of an in between idea (or maybe it's the same and i misunderstood the above)... I'm assuming cqc supports server side variables (haven't look yet), but assuming so, i can read/set those... i'm sure upon saving changes, i can write to the cqc variables and send the elk passthrough command to sync them up.
The whole point here for me is to avoid using elk keypads or elkrp to change thing like durations (be it sprinkler / pool pump / etc). Doesn't really matter what drives them from the change point of view...
The only issue would be elkrp would catch the delta when i do need to program and reset, but i can live with that... Need to check elk rules, but if i can compare sutom setting values for eqaulity, i might be able to have elk raise an email or keypad display if they get out of sync too...
-brad
-brad
