I wonder if someone can help me with port forwarding for the M1XEP.
My router/firewall, CheckPoint's UTM-1 Edge W, offers me "allow and forwarding" or simply "allow" from a connection source to a destination source. I can designate the specific TCP port(s), but I can't figure out whether I need two rules for each of the four ports (2601, 21, 26, and 80) to allow both incoming and outgoing or whether the ports only need to allow incoming traffic. I've been assuming the router needs to "allow and forward" the connection from the WAN (internet) input on the router (other options include ANY source, "this gateway," or individual network objects or static IP addresses) to the ELK M1XEP network object which has a static IP (rather than to "this gateway" or LAN or something else). Does that sound right? I've absorbed as much as I could from portforward.com, but that site does not have my router or any details for the Edge.
I've set up a DDNS on dynDNS, but I can't get that to work either, and I don't know if the problems are related or not. I'm on comcast, and nslookup returns the correct outside IP but I can't access the outside IP address from outside the network, and when I try it from inside the network, it pulls up the login page for the router.
Thanks for any suggestions.
