KenM
Hi all,
I have a 1959 vintage house in Southern Ca. The 'electricians' who originally wired the house used an outlet in the back bath as a connection point to all of the outlets in the back bedroom. All of the outlets are two pin, no ground type.
My concern (other than I need to rewire the whole place) is that the back bath outlet sometime will get quite warm/hot when the back bedroom is using above about 1000 watts of power. I have replaced the wall junction/outlet in the back bath, and have verified that the connections look good. At the back bath outlet, the two wire connections are both solid copper wire that has been 'connected' by the screws on the outlet. They still get warm/hot.
Here is my main question: If I solder the wires at the back bath outlet (to lower resistance/heat); Which codes might I violate.
Opinions and suggestions (other than get a new house) are welcomed.
Thanks All
ken
Thanks All
ken
