Hi, I'm looking to replace my builder-grade panel with an Elk M1G, partially to add some new capabilities right out of the box, but partially because I want to be able to eventually expand my integration between it and the rest of my HA setup.
I've got a few remaining specific questions I hope people can help me with here:
1. For some asinine reason, my builder only included one doorbell, and it's upstairs (handy if I'm upstairs, but I can barely hear it downstairs if the TV is on or anything). I thought it would be a good idea to use a doorbell interface, and just have a rule or something that puts an announcement out at the keypads (M1KP2 with speaker behind). What would be the latency of such a setup? Would it be more or less instant, or is there a few seconds of lag? (and if I DON'T use KP2, can I make a KP1 beep/buzz with specific tone or something?)
2. On the KP2. I see the KP1 has dimmable illumination, but I can't find anything that says that for KP2 (which would be directly viewable from my bed). Is KP2 dimmable?
3. I can't seem to find the right speaker/part for attaching a speaker to the KP2 back box. Anyone have a part no or link?
4. My builder used a 4 wire hookup for the keypads, but in a moment of foresight, I had him run Cat5 to each keypad location. These are terminated in a patch panel. Will this work to connect the Elk databus hub -> patch panel -> keypads?
Any additional advice on keypads is welcome. I like the KP2 because I think it looks better and can support a speaker behind it. I pause because I'm not sure I can dim the lights on it and it doesn't have a cover. (Do the lights at least dim or shut off when not in use)?
Thank you!
Thank you!
