Hello,
I have an OmniPro II and Haiku installed on my iPhone. I have haiku successfully working from within my local network using a wifi connection. I want to use Haiku remotely though via LTE.
I have set up a dynamic DNS and can successfully get to my routers outside public IP via the assigned host name. In the router I have forwarded port 4369 (kept default port in OmniPro for now) to the OmniPro IP address.
Final step was to edit controller connection in Haiku to address of my DDNS host name. Everything else remains the same....port number, private keys, etc.
But....I get connection failure.
Is there more to it than this? I'm also confused how it would ever work without the OmniPro having a default gateway IP address. Doesn't it need this to know it's return path back to router?
What can I do to test if port forwarding is working correctly?
Warren
Warren
