Has anyone considered whether relay switching of a modem/router/electronic device can cause damage? The Baytech switch looks like a nice device, but I question whether it's wise to use this with "consumer grade" electronics.
Most of my information is rather date (80's and 90's), but we were required to provide a fair amount of Hardware protection to devices using EEproms (Aerospace applications). At that time, simple software write protection was considered insufficient to prevent a EEprom from being scrambled during power-up/power-down sequences. I've browsed over some of the currently available devices and it appears that they've improved over the years, but I'm not sure that means they can't be upset during power-cycling.
I would also be concerned about how multiple powered devices discharge when power is interrupted (by a relay or a switch). You'll have stored charge in these devices that is searching for the least resistance to ground. If that path happens to be through a nearby component, you could easily overload the neighbor.
I would never consider connecting a TV, PC, or other "complex" electronic unit to a switched outlet for exactly this reason. All of my devices are powered by un-switched outlets. I typically run around powering device down when a storm is approaching to prevent power cycling of these units.
Case in point - '95 vintage Toshiba 55" projection unit.
I forgot my rule of un-switched power when I moved into my new home in '2000. Plugged the projection TV into a switched output in the basement. My 5 year old decided to life test the wall switch with the Toshiba connected (entirely my fault for connecting the set this way). Symptoms - TV would power up for roughly 30 seconds but then loose video (audio only). After ~1 week of playing I realized that the setup parameters in the EEprom had been scrambled. These parameters controlled the "drive" to the crt's. The crt's were being over-driven and the set X-Ray protection was kicking in to protect nearby viewers (me).
I would love to learn that I'm just a paranoid old man, but I suspect that susceptibility to power cycling varies by manufacturer. Please educate me if I'm off base here.
IM
