roussell
So, I'm in the process of switching from a combination of Windows/Housebot & Linux to a Mac Mini running Indigo. I have two of the 4 port Quatec QSE100D serial to ethernet converters, and a Wiznet wiz110sr that I've used flawlessly with Windows based drivers and socat on Linux.
I can't seem to find any drivers for the Mac (Snow Leopard) that will allow the converters to work with a Mac GUI app. socat will work fine for the numerous scripts and various shell apps that can read from "/dev/ttyxxx" but Indigo as well as most other GUI apps I've encountered don't seem to interrogate the /dev tree for the serial ports. They all present a drop-down that forces you to choose form a list.
I have ran across an app or two that claim to do what I want (an app called Multicom is an example) but they're really all just wrappers around socat or netcat. Apparently, OSX is taking and extra step in defining serial ports and exposing them to applications that I'm missing. BTW, I've tried symbolic links to a socat-created virtual tty to attempt to replicate the Mac's naming convention for serial ports but that didn't work either.
The main thing pushing my quest is that the HA gear is about 70 feet and 2 floors away from the Insteon PLM. The PLM is plugged into a wiz110sr serial-to-ethernet in the basement by the breaker panel and the HA server is on the opposite corner of the house on the second floor. The solution has worked great for well over a year now with Windows/Linux so I's like to keep using the S2E converters if I could find a freaking driver for the Mac...
I've asked on the Indigo board, sparkfun board, on Quatec's support forum, and have googled until my fingers are numb... Any ideas?
TIA,
Terry
TIA,
Terry
