apostolakisl
http://www.totalbarcode.com/prodimages/gesecurity/400.pdf
This pdf gives a summary of what the letters stand for.
There is a model with both end of line relay and built in sounder, 449CSTE. In my mind, this would be the best unit for around the house. Each unit would signal trouble (clean me) to the panel, eol relay is built in, they all have sounders (need to intall a reversing relay at the panel for all to sound simultaneous), they all alarm the system in the event of smoke or heat.
The 449 CSRH unit could be used in the kitchen. It would report only heat to the panel, but it would sound locally for smoke. So your burnt toast doesn't call the fire department but still gets you into the kitchen to check it out. This unit does not report cleaning to the panel.
