Desert_AIP
I've got my entire UPB install reconfigured from UPB to HLC and allocated my "rooms" and switches.
I've read through the "Configuring non-HAI UPB switches to use HLC" docs and looked at the spread sheets.
I understand the room scheme and the 6 links and 8 units and the room controllers and links.
This part is stumping me.
"Links 243-250 – assigned to any HSS configured to function as a macro-executer"
Is "macro" here being used as a synonym for HAI "Buttons"?
If yes, are these simply links set aside to execute buttons from a UPB/HLC link?
If yes, what will happen if I use those links for general UPB links?
I don't see any embedded functions for those links, though they are noted as "reserved" in the UPB scene setting section of PCAccess.
I assume that I configure the HSS and use those links from the buttons by writing programming that says "when Link 243 on, then execute button X".
So if I don't write that code, can I use these links for other functions?
What does the controller do or expect when it sees those links?
