cobra said:
Got a material quote back from SmartTint at ~$1000, which isn't as bad as I expected. And 1/3 of that is for their dimming controller, so the shade material is about $600 for two windows. The downside is that while they said it was compatible with home automation systems, they mean you can hook in to the relay for on/off control.
They specify that the dimmer must do true sine wave control. Anyone know of a pure sine wave UPB/ZWave/Zigbee dimmer? (it'd probably need voltage control as well, but was looking around to see if anything like this existed.)
I went down this path with Smarttint. Spent $1,200 for one large window and replaced their remote cheap control with a Z-wave GE On/Off switch. Worked great. I replace the On/Off switch with the dimmer switch and with the first try the connectors on the film got fried. Sparks all over the place. I tried to make it work again but it burned a hole into the film.
I will not discuss the rest of this story as this ended up in the New York court but bottom line is that they tell you it works with "home automation systems" and they name some of the high end ones like Crestron but in the end you have to use their tools and apps from them. I was offered a software/hardware combination for $1,500 which would allow me to control my film(s) from my cell phone but the whole purpose of my home automation system is to have everything in one single app and control my whole home within one framework which also enables voice control having to deal with a single system and not multiple ones.They were aware of those requirements from day one as I was very clear about them. Once you buy their product, it is yours and they go as far as blocking your email address on their mail server.
If you are simply looking for On/Off I can tell you that it worked. Will it work over a long period of time without frying the film? I don't know. Will they support that? I don't know. Work with them and maybe you have better luck than I did.
If you are looking to dim the film which most people would want, then don't try anything else than their provided hardware/software combination.
I do want to add that I was impressed with their film from a technological point of view. I tested it during the day and during the night. I was concerned that during the night, you could see shapes and shadows through the film. I can say that I was wrong in that assumption. The strange thing is when you are standing outside your home and you look through the window with the film on (opaque), you can see the light bulbs of the room shining through the film. A person can stand right in front of the window from the inside and you will NOT see that person. Somehow my Philips Hue bulbs emit on a frequency which penetrates the film but you cannot see anything else through that window. Very impressive film technology from Smarttint and I wish it would have gone differently with those guys.
Another important aspect which most people don't know about. The film works with power but in my opinion it is reversed, let me explain. Per default the film is non-translucent which means you cannot look through when no power is applied. To make it transparent you have to apply power. If your house looses power, your windows will be non-translucent which means you cannot look through them. Some people argue that the privacy is maintained by doing it this way. Other people like me don't think this is how it should be and here is an example confirming my theory. Smarttint gets also applied to cars. Imagine you are on the highway with 65 miles per hour and for whatever reason your car has no more power (battery failure with engine outage or pick your choice). I don't want to be in that car when that film becomes non-transparent at that speed!
Good luck for your projects guys as I just wanted to share some experiences and thoughts on smart films!
