JDuc
I appreciate all of the replies!  I guess that this is a topic that is quite intriguing for some based on the replies I see here.
Ideally, I don't want to be watering when it's not necessary. Not watering when it's raining is easy. Rain sensors are a dime a dozen.
This could be done by zone I would imagine.
You bring up a few points that make me realize I'm still needing to do some research. I'm guessing that there's a few differences with the ET systems and what you're pointing out with the Rain8Pro?
This is what I was thinking would make the most sense. I was under the impression that ET type systems might utilize moisture sensors as well as current, past, and future weather conditions to determine if you needed to water. My thought was to keep my current zones and just install moisture sensors in those zones in the ideal locations. Only water specific zones as necessary based on conditions. I would want to tie this into the Elk system in order to tie everything into one central location.
This sounds like it would be ideal for what I was envisioning. Sounds like you're already all over it though! I suppose I just need to figure out what hardware I can use for this set up.
Again, I really do appreciate all of the discussion on this topic!
			What exactly do you mean by "only run when its needed"?
Are you trying to not have it run when its raining?
Do you only want it to run when the ground is at a certain moisture level?
I have been trying to find a ET or moisture based system that can be integrated into Elk. I really hope someone would build a self-contained (read low-cost) ET system that uses serial communications to provide input information to HA controller. I have yet to find such a product. The closest I can find is a Hunter SolarSync or Hunter ET-sensor. From my research, the ET-based systems produce a “good-enough” calculation with the added benefit of not relying on a single in-ground sensor. In addition, the in-ground sensors have to be calibrated.
As an alternative, I believe it would be feasible to integrate either of these products into a Rain8Pro. These products use moisture sensors which mayproduce unstable readings depending on the quality of moisture sensor.
FWIW, I've been running a ET based water balance system starting earlier this year and found it to work quite well.
It turns out that since you water a whole zone at a time anyway, then you just have to model each zone based on the most stringent conditions within the zone to make sure that everything within the zone get enough water. Some parts of the zone may get over-watered, but that issue exists within a zone even if you schedule manually.
The CQC irrigation scheduler which I use and wrote does manage each zone independently. You can specify the parameters for each zone including soil type, vegetation type, sprinkler flow rate, sun exposure, slope, etc. The water balance is maintained for each zone based on rainfall received, weather forecasts, and evapotranspiraton. So far, it has worked well.
