Reading through the search results I got on smoke detectors, one thing that isn't clear is how you guys that have integrated DC-powered smoke detectors (regardless of whether 2 or 4 wire) are meeting building codes which in most municipalities seem to require 120VAC powered SD's from the house main supply, and all linked together, and with battery back-up?
Are you leaving those original builder-installed detectors untouched (and unmonitored by the ELK), and the DC powered detectors are a supplement to that so building codes don't directly come in to play?
Another interesting thing I've come across, and I had never heard/read before, is that the National Fire Protection Ass'n recommends all smoke detectors be replaced at 10 years, regardless of whether they still appear to be working, because their data shows those old detectors have a 30% chance of failure going forward from there, due to various aging effects.
30% failure probability is pretty high for such an important device, so I plan to replace my 120V powered detectors too. Or maybe there is a way to cover it all with new DC powered and monitored detectors?
I wonder how many other people are unaware of that recommendation to replace after 10 years. Probably a lot, I would guess.
EDIT: How do you modify the title of your post? I'm not seeing a way to do that.
