felixrosbergen
Gents,
My plan is to not have any Cat5e or RG6 put into the new house by the builder, instead i have him put in several 2" PVC conduits from basement to attic and at all locations where i want any type of media outlet (Cat5e, RG6, IR, Serial, whatever) i will have a LV mudring with a flexible conduit (e.g. smurf tube) runnign up to the attic or down to the basement.
The smurftube would have a max lenght of abotu 9' for 2nd floor to attic runs and probabaly only 5' or so from ground floor to basement.
Since they are only running up/down to attic/basement i expect the runs to be relatively straight with few turns. If the LV udring is nailed to a stud then the smurftube and go straight up the stud with some clamps.
I am trying to figure out the right size conduit. Looking at HomeDepot it seems that 3/4" is pretty common and has connectors and stuff to the LV bracket (Organge Carlon stuff).
Ofcourse not all places may get 2RG6QS and 2 Cat5e, but generally if that can fit i think i can fit most of my needs. I dont' plan to run component cabling or anythink like that. At the main TV location i've asked for a 2" conduit to basement for flexibility (possilby HDMI from media PC/server downstrairs or may even put surroudn amp in the basement).
Would a 3/4" flex conduit allow a bundle of 2 RG6QS and 2 cat5e to be pulled through? I checked it at HD and it physically fits in there...but hard to say how well it woudl 'glide' through the conduit.
THought i'd give this forum a shot before i go by 9' of tube and 20' of RG6 and Cat5e to try how well it works...
Separately I'm having them upsize a lot of light switch location with an extra gang and a similar smurftube configuration to allow me to add the hardwired control for OnQ ALC and possibly some other IR/Intercom/whatever...
