v1rtu0s1ty
Here is an update. I can arm it via RP2 software but not via the keypad until I open a door with sensor. Scratching head!
Had same problem with Rules and text showing conflict, and FW upgrade fixed it (have most recent RP version as well). But no idea if it will address your original problem.v1rtu0s1ty said:Also, even if I send the checked items to the system and saved it, the next time I connect to my M1 via RP2 will show this screen again.
Is there an incompatibility with my old firmware and latest RP2 software?
This will always happen if you have notes or disabled rules - because those aren't sent to the panel and therefore they're always different on the local copy.v1rtu0s1ty said:Also, even if I send the checked items to the system and saved it, the next time I connect to my M1 via RP2 will show this screen again.
Work2Play said:This will always happen if you have notes or disabled rules - because those aren't sent to the panel and therefore they're always different on the local copy.
It should always be safe to send to the panel for rules/text since those shouldn't change outside of RP anyway.
