v1rtu0s1ty
I didn't access my M1 via RP for more than 1.5 years and there was no weirdness. Few days ago, I downloaded the latest RP so I can create rules for my sprinklers. I didn't upgrade the firmware. I noticed though that I can't arm it. I tried using code, it didn't work. I tried the arm stay, it didn't. This was from 2 days ago.
This morning when I looked outside my backyard, one of the sprinkler was watering the lawn. I went down to look at output 10 which is the one were the running sprinkler was connected. However, keypad shows OUTPUT 10 was OFF. All 5 sprinkler valve's OUTPUT was OFF. I pressed # on OUTPUT 9 to turn it ON. Please see attached pictures so you'll see how my sprinkler rule works. At this time, 2 sprinklers were running which is fine. OUTPUT 9 is also showing ON in keypad which is fine. OUTPUT 10 though was still set to OFF which is ok because we already know there is something going on. I went back to OUTPUT 9 and pressed # to turn it OFF. It stopped watering which is good. OUTPUT 10 is now ON and since it's already watering, it just continued watering. I pressed # on OUTPUT 10 to turn it OFF, it stopped watering. I did the same for OUTPUT 11,12 and 13 without any issues.
When I pressed ARM STAY, it would just beep and not arm the house. I tried my secret code but it didn't arm the house. Though I knew how it would arm, I still didn't do it so I can troubleshoot. I gave up clicking on the keypad because it wasn't arming. The workaround to make it work is to open any door/window with a magnet sensor. I did and I was able to arm the house. That's what I did too 2 days ago.
To put it in a nutshell, I have 2 issues.
1. Sprinkler on OUTPUT 10 is turning ON even if OUTPUT 10 on keypad is showing OFF
2. Unable to disarm the house
For issue 1, maybe it's a bad Orbit valve. I will buy a new Orbit valve later.
For issue 2, I have no idea what to do.
Please let me know what you need from me so you can help me troubleshoot.
Thanks!
Thanks!
