On the subject of heat but off the subject of energy usage - I was thinking of a modification of one of the bedrooms heating over to "floor" style heating.
Looking for ideas. The bedroom has one duct for forced air/heat and one return. It sits over the garage and therefore (my guess) is always cooler / warmer than the rest of the bedrooms. I had been considering ripping the carpeting out and maybe putting some electric elements down and putting tile down over this. Hot water heat could also work but I have never done this and know nothing about doing this over wood.
Floor heat is nice because it radiates upward. If you used forced air before and kept the house at 70, setting the thermostat at 60 with in-floor will feel about the same.
Laying down electric elements is probably going to be cheaper than doing hot water (hydronic). But, there are benefits and drawbacks to both. And if you plan on doing a large part of the house rather than just the bedroom, the hydronic could turn out to be cheaper because the price difference on a small boiler versus a large one with the stuff I got was only a couple hundred bucks. My boiler was around $700 when I bought it last year, and it's large enough to heat the whole house.
There are a few different ways to do hydronic on an existing installation:
- Attach the PEX loops to the bottom of the subfloor and get the heat to radiate through the wood. (Bad idea, but some people do it)
- Cut a series of 3/4" wide channels in the subfloor, insert these aluminum plates with a channel that sits down in the slot you cut, run your pex through that. It works, but those aluminum plates can add up in price. Plus, you don't really have a good thermal mass to retain heat.
- Get some plastic framing stuff that sits on top of the floor and has slots to run the PEX. Then put cement board over it and then your flooring. Raises your trim by 1", and you'll have to cut the bottoms off doors.
- Put down adhesive foil to the subfloor to reflect heat back up into the room. Anchor the PEX to the subfloor to hold it in place, and pour enough gypcrete to cover the PEX. It still raises your trim, but you get a ton of thermal mass from the gypcrete. It's probably the cheapest option also.
You'll need to hook each of your PEX loops into a return and supply manifold, and then these go to the boiler system. I built mine, a photo is attached below. Basically it's just a pump controller, a boiler, air eliminator, some pump flanges with fill spigots, a purge valve, a filter, and some other stuff. It cost me about $2200 for everything, but as I said, it could heat the entire house by itself. I could have bought a premade panel that was almost identical for about $1k more.
And, it's 100% efficient, which you won't find with a gas forced air system.
