upstatemike said:
If I can't do that right away then I am out a lot of money AND would have made no headway on enabling Insteon control. It would be a BIG risk!
I might be misunderstanding, but isn't there's $$ risk both ways?
If you stick with the SG:
If you buy CQC now, your $$ risk is that you've wasted $500 on CQC. Of course, you could run it just to get that cooler Slimserver GUI and add the new stuff on slowly as you bring it online. I.E., potentially even the weather stations, so i'm not sure it would really be a total loss or "sit on the shelf" situation.
If you don't buy CQC now: Your $$ risk is that you'll need to do that incremental software costs to support, as mentioned above.
You could hedge against your lack of Elk by using your $500 CQC investment to do as many of the incremental bits as possible, hence reducing the need to the extra software bits. Over time and as drivers that interest you become available, you could add those on. For example, I know that i'm personally looking to commission work on VR and RFID in the "no less than 3 months, no more than 12 months" timeframe. One of the guys may have a line on some decent RFID hardware so that's probably first, although Paul's VR demos certainly are slick and there's a few rooms that I could really use it in.
If you stick with the Elk:
Well, you already know that bit.
Anyhow, good luck to you in whichever path you choose to go down. I'm sure you'll make the right call since you'll probably end up adapting your needs to it's strengths.
If you want a webex of how CQC works, i'm happy to find some time to do that. Understanding it's approach to helping you build out your HA could be the deciding factor in whether you love it's approach or hate it, which would be the "special sauce" in making you successful.
