I didn't know about their existance until a few minutes ago! I am dying to automate some of my switches (they used to be cheap x10 switches, but they all died after a few months), control my outside lighting, turn on walk in closet lights when door opens, stuff like that, but I have toggles at home (so Z-Wave is out of the question), so I am very excited to find out Martin carries these.
1) The only thing that I can't figure out is, are these 'push up/down' switches, kinda like the cheap x10 rockers, or is there a true on/off state?
2) What's the difference between the ToggleLinc 2-Way Dimmer, 600W and the ToggleLinc 2-Way Switch, 5 Amp?
edit: figured it out after checking smarthome.com, looks like the 5amp is like an appliance module?
3) My outside lighting is just 4 60W bulbs, most other lighting is just a single 60W bulb. What's the maximum they can handle?
4) Any reason I shouldn't get these? Should I just replace all my toggles with rockers (depending on WAF) and get the regular switchlincs?
5) Do these support 'soft starts', so they can dim from OFF (unlike the cheap X10 ones which go full bright first)?
Thanks guys!
Thanks guys!
