I have an OmniPro II and the Kiddie SM120X relay connected to my 120v existing smoke detectors.
The setup seems to work fine and triggers properly when any of the interconnected smokes are tripped. However, twice in the past 2 years (including last night at 3AM, of course), the Fire Zone has tripped with what seems to be no activity from the smoke detectors. That is, the alarm panel triggers it's fire alarm but the smoke detectors are NOT in any alarm state. During this time there was no fire, no power loss or spikes of any kind, and nothing that I can discern that would cause the relay to close.
The SM120X is wired using the NO contact with a 1k ohm resistor in parallel at the relay. The OmniPro shows the loop value of this zone at about 145-146 most of the time, which is consistent with the other zones on my Expander Board (all of the expander zones live in the 145-146 range for loops while the non-expander zones are usually in the 148-150 range....not really sure why).
I'm using Zone 17 (EX-1 on the expander) set as type "Fire Emergency".
Any ideas why this would randomly trip an alarm? Is it ok to have a Fire type zone on the Expander? Should it be "Fire" or "Fire Emergency"?
NOTE: I'm aware of and respect the disagreement for the application of this relay for monitoring of this type. For me, my panel is not monitored so I believe this application augments the fire protection and does not replace it.
