I am having some issues with my 32" Philips TV, and it really is starting to become a problem, so I figured I would start a thread about it, in case someone else has run into this issue.
Whenever the TV hasn't been on for a while, it won't turn on correctly. When you first hit power on, it turns off immediatly, and does this several times. Then once that issue is gone, you need to keep switching the channels for 40 or so seconds (using the remote, local controls on the TV don't fix this problem), or it will turn off again (and start all over). Once you hear this really loud squeeling noise (and you can see some weird effects once the pictures shows), you can stop changing the channels, and it will stay on. Since this is a really nice TV (2001 model, so it isn't that old), I really want to figure out what's going on, but am afraid of taking the TV apart to look at the electronics.
Any suggestions? Thanks!
