WayneW
I think this is what you want. This uses out16 as a delay timer. You could have something hooked up to it, but I suspect you are just trying to use it as a delay. If that is the case, then I would suggest changing it from out 16 to out 99 or something that doesn't exist to avoid wasting hardware resources.
Whenever Close Roof (task 3) is Activated
Then Activate Park Telescope 1
Then Turn Output 16 (Out 16) on for 1 min
Whenever Output 16 (Out 16) turns off
Then Turn Close Roof Sw (Out 10) on for 35 sec
