PaulD
I need to determine how I will use UPB to control ceiling fans in a new house. As far as I know, no one makes a UPB variable speed fan control today so I am looking at my options for fan control with currently available switches. From earlier threads, it appears that I can use a UPB switch for on/off in series with a traditional variable speed fan control (non UPB). I only get on/off control via UPB this way but that is better than no UPB at all. Not a full UPB solution but it is acceptable until someone makes a UPB switch with full fan control. Have others used this approach successfully?
In this configuration, I am assuming that the non UPB variable speed control would be wired in series on the hot leg between the UPB on/off switch and the fan. If I am on the wrong track, educate me.
PS....I have heard that some other technologies may have fan switches already. Even if true, I do not want to mix anything with my UPB.
